Install CINESSD
Hi, I want to know if is neccesary the license key to see a cinessd 240 gb, because I have bought a cienssd 240 gb and I connect to my inspire 2 but it don´t recognize the cinessd.I have not a license key because I only want to film full HD video and 20 mp photo, I dont want proress and cineDNG format.
Please can you help me .
PABLO
Reactions: marctronixx
If you don't have the licenses for ProRes/CinemaDNG then you can only use the cinessd for raw-burst photos ... you have to chose photo burst mode and select a frame rate of 14 or more frames per second.
Unfortunately you cannot record h264/265 video or non-burst photos to it. :(
But I want the cinessd to film in full hd and photo no more, I dont need to 5.2 k film, but I ask if I can install the cinessd without the license key to film in full hd format, no need prores or cinemadng, if is posible, can you said me how ? thank you
Unfortunately, because of the way the Inspire 2's image processing system is designed, it is not possible to record 'full hd' H264/265 video to the CineSSD, nor is it possible to store normal jpeg's or RAW images to it. You can only store ProRes/CinemaDNG and RawBurst DNG images to it.
Ok thank
Ok but, in no manual say that I need the license key to use the cinessd, and that I cant use it to film full hd, this is what I find frustrating, because I only want a more reliable and faster device to read and write than the microSD memory, and nowhere say that I need a license key to use it. Thank you NickU
If you use good quality microSD cards then you should not have problems recording h264/265 to them. I've not experienced any problems using the Sandisk extreme pro 64gb cards, I'm sure they're at least the 90Mbps (write speed) versions.
You may have problems with slower cards... some lexar cards I have are too slow for the x5s/I2, instead I use them on the Phantom 4 and Osmo/X5.
Reactions: mpaerial
I havent problem with microSD, I only want a more reliable and faster device to read and write.
It is in the manual, perhaps not as clearly as you would like, but it is there:
Video Formats
SSD: CinemaDNG, ProRes
Micro SD: MOV, MP4
abseilerstu
